Just in case my wife gets trigger happy with the delete key.
Turn off the allow media deletion option in the library settings. Will then only be able to remove shows by deleting them from your device file system.
Thanks, but I was thinking there should be a way to protect only certain recordings, not all. Would be nice to have an option in the Plex that you could check a tick box.
I’d suggest having a different user for your wife, and only allowing the admin to delete.
