Is there a way to repeat a playlist?
roku
#1
I sometimes like to have an music playlist repeat when it's finished. I saw the looping icon by the controls and assumed that was what I wanted, however it's per song and not for the playlist as a whole. I mean every song in the list will repeat, but individually which was not exactly what I was shooting for.
To be clear, I would like every song on the list to play once and then cycle through the list again. I can't seem to get this to work.
#2
The repeat button has three states. Off, repeat single (current track), repeat all. Press the repeat button to toggle between the states.
#3
That's brilliant! Tried it and it worked perfectly.
#4
It's possible I spoke too soon. Just ran an 82 song playlist last night. It made it's way through the initial run just fine but then on the second pass, songs were playing off the list at random. I double checked and did not somehow accidentally set the shuffle button. Is this a known issue with long playlists?
#5
There is no known issue there. The list should wrap accordingly, you should see this if you look at the queue when you are towards the end. It will show tracks, ... 80, 81, 82, 1, 2, 3 etc. Is this not the case?
#6
Rebooted the server and things started behaving better. Not sure what was going on there.
#7
Hi guy, I do not see a way to repeat an audio track / playlist in Plex 1.5.3.3580 for Linux (Synology DSM).
The Repeat functionality does not work in the desktop client, no matter how many songs in the playlist.
I also purchased the Android app, this seem not having the toggle repeat button at all (Android app v6.3.41485).
Am I missing something?
#8
It seems Android and web app have no repeat button?
