So, I’m noticing that if you rate a music track, that music track receives the same rating on all albums where the track is found. Mostly makes sense, but sometimes the tracks are a tad different, however that might be a side topic.
The topic here is an issue when you attempt to create a playlist or collection using track ratings. Let’s say you want a playlist of your 5-star tracks. Let’s also so that a few of your 5-star tracks appear on multiple albums. Well, the playlist or collection will now contain the same track multiple times.
Since the ratings are automatically carried across albums, there isn’t an easy way to remove the multiple tracks.
I have the same issue. I have 2 Plex servers. I am replacing Personal Cloud 1.28.1.6104 with MyCloud 1.29.1.6316 and I have to manually update the Meta data which is a pain because there is not an upgrade path to replace old servers. Anyway, the Personal Cloud keeps all the Music Rating separate from each other, where as the MyCloud changes the star ratings across albums. This leads me to believe there is a way to turn this feature on and off but I haven’t found the setting.
