issue with TV-Shows
server-synology
#1
Hi all
I've an issue with a tvshow. In fact I've created an own tv show and added some metadata. The name and the episode will be recognised by Plex but the episode description is blank, the "aired" date and the age rating as well. For the tagging I use iFlicks (v) and Meta X. Further, the tags are available in a XML or NFO file.
#2
Plex only reads episode names from mp4 / m4v files.
If you have Kodi-compatible .nfo files, install the .nfo importer agents. then perform a ‘Fix Match’ with the show.
Select ‘Auto-Match’, - ‘XBMC nfo tv importer’
#3
Hi - will try it today However, the affected files are mp4 - However, Thanks
#4
Make sure 'Local Media Assets' are activated under
Settings - Server - Agents - Shows - Personal Media
