iTunes crashing Plex
plex-classic-for-roku
#1
In the Plex iTunes channel on my Roku 2 XS, I'll select a playlist and it will play one or two selections from the playlist before crashing the Plex application on my server. I'm running Plex version  0.9.9.14 under OS X version 10.9.4. The Roku is running the latest version on the PlexTest channel. What information do I need to send you so you can debug the problem and where is it located ?
#2
Upgrade your PMS. I believe an iTunes server related crash was fixed in 0.9.9.15 (0.9.9.16 is now available)
#3
thanks
#4
I have the same issue, but I see neither .15 or .16 versions available as downloads.
[EDIT] Let me clarify, this is not the same issue of where selecting itunes crashes plex on the Roku. That has been fixed.  Now selecting itunes crashes my PMS, requiring a restart of the server application on my PC, and then they work fine together.
#5
Those downloads are Plex Pass only now. https://forums.plex.tv/topic/62832-plex-media-server/
You could try downgrading the server to an earlier version until the newer releases are public.
  Archives: https://support.plex.tv/hc/en-us/sections/200287708-Downloads-Archive
#6
Thank you. I'll give it a try.
The .15 and .16 versions have not been officially released but can be downloaded if you are a PlexPass member.
#7
@Plutonius said:
ljunkie wrote on August 18 2014, 2:47 AM: »
Thank you. I’ll give it a try.
jonsarik wrote on August 18 2014, 2:28 PM: »
I have the same iTunes crashing issue, but I see neither .15 or .16 versions available as downloads.
Will try it
#8
How about upgrading to the latest version?
