Itunes not showing up
#1
I am trying to link my iTunes media with plex. I have followed the directions on the plex how to for adding iTunes into the channels list. I have enabled it and restarted my server. Nothing shows up in the channels page, I have also added the file path to the iTunes.xml. I am having no luck with adding iTunes any help is appreciated .
#2
Same thing here
#3
you can check your iTunes settings. in the “advanced” section there should be an option to share the iTunes xml file from other apps – is this option checked?
also… do you run the Plex Media Server on the same machine where your iTunes is installed?
#4
Yes, that option is checked and yes, both are on the same machine.
This used to work, only recently did it stop working for some reason. After a plex update.
#5
Sorry, I figured it out in my case. Windows 10 iTunes App install uninstalled the main version. Once I uninstalled the app and put back the main version of iTunes it came back.
Thanks!
