iTunes playlists not loading
server-qnap
#1
Hi I cannot get itunes playlists to load into Plex on my QNAP NAS Drive. I can see them in the iTunes channel but they won't play I get an error message "shaka1001 (Network)'. When I try to import from itunes into playlists It only brings on 4 generic playlists not the ones from my Itunes library. I have tried everything. What am I doing wrong?
#2
iTunes import requires that PMS is executed in the same machine as iTunes. iTunes is not available for Linux systems, and consequently not in QTS.
When PMS is installed in QNAP you may try another method -> https://forums.plex.tv/discussion/comment/1138209/#Comment_1138209 (valid for Synology, but probably also applicable to QNAP with different file paths).
