Keyboard controls Plex for Kodi
plex-for-kodi
#1
Hi all,
I was wondering if there's a Plex specific keyboard shortcut to take me to the home page of the Plex app for instance. Currently when I press the home button it takes me to the Kodi homepage.
#2
esc should do it.
#3
That seems to take me back to the previous page. Would it be possible to program a button to have the same function as pressing the top left home button within the addon?
#4
What button would you make this? possible yes, and I can see its usefulness, and can add it to the list of keyboard controls we need to add.
#5
I would reprogram backspace as back and escape as home imo.
#6
I agree, that would be the most logical solution
#7
It would mess with many remotes which don’t operate like that, so I’m not sure that’s an option.
#8
Perhaps just a random key not in use by Plex then? Since I generally use a simple remote control I’m not sure which ones fall under that category…
#9
@keithah
Why not just mimic the Plex Media Player keyboard shortcuts?
Go Home : H
Toggle Subtitles: L
