keyboard shortcuts / kodi shortcuts not working
plex-for-kodi
#1
As the title mentions...
I am running Kodi 17.3 with the latest Plex for kodi plugin (from the repo), however when I try to use my remote to control the video, the pause / play / stop works as expected, but the bigstepforwards / skip forwards does not work and I have to use the arrow keys on the remote to hightlight the correct button (fast forward) to start it going.
I am using the keyboard.xml to modify what each button does.. so wonder if that is impacting things I have :
<<< see below message >>>
I generally use the up / down / left / right for bigstep / etc and its not passing the WAF currently :smile:
Any help you can offer is greatly appreciated
Phil
#2
PlayPause
Rewind
FastForward
SkipPrevious
SkipNext
Pause
Stop
playpvrtv
NextSubtitle
ActivateWindow(home)
fullscreen
ContextMenu
ActivateWindow()
PlayPvrTV
ChapterOrBigStepBack
ChapterOrBigStepForward
AudioNextLanguage
OSD
StepBack
StepForward
StepBack
StepForward
PlayPvrTV
AudioNextLanguage
OSD
StepBack
StepForward
StepBack
StepForward
PreviousMenu
Record
#3
There seeking/skipping support in the add-on is lacking. I don't think it supports modified keyboard.xml at all. Nor will changing the Kodi player options work in the add-on
See here for a bit of an explanation of how things currently work.
http://forums.plex.tv/discussion/262434/skipping-forward-backward-takes-many-key-inputs#latest
