[LG TV] No Audio DTS XLL
Server Version#: 1.32.6.7521
Player Version#: 5.69.1
For some reason, the player on the LG TV does not play the sound from the attached video during direct playback.
sample.zip (7.7 MB)
Audio
Format : DTS XLL
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
Codec ID : A_DTS
Duration : 18 s 17 ms
Bit rate mode : Variable
Bit rate : 3 595 kb/s
Channel(s) : 6 channels
Channel layout : C L R Ls Rs LFE
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 24 bits
Compression mode : Lossless
Delay relative to video : 2 ms
Stream size : 2.68 GiB
Title : DTS-HD MA 5.1 (Untouched)
Language : Japanese
Default : Yes
Forced : No
