LG TV Remote Volume down button is forwarding video playback by 30 seconds
plex-media-player
#1
Searched the forums but can't find a solution other than to remap keys my LG TV remote volume down button is skipping video forward 30 seconds and it is really frustrating. I need help to either re-map or find another way to change the behavior.
As per create-your-own-inputmap I was looking for the keymappings file to remap the specific button but I have had no luck finding the location i should save the file in. The plex app logs also do not list the remote control name or key presses either which is odd, unless i am looking in the wrong place (I enabled network logs, using browser to search them).
Any advice would really be appreciated.
#2
are you actually using PMP? you tagged plex for android in the thread?
#3
darn, thanks Dan, will post under android.
