Server Version#:
Hello,
I just finished setting up my plex server via truenas scale 25
but plex detects my media at the wrong quality.
all my media are 1080p in H264 or H265 format but plex says they are in original quality in 480p or 720p
It may be related to the fact that I used the command parse library (which in theory should Parse library files extracts information that helps Plex play media files in the best way.) but concretely it imposes a low quality on all media that I can no longer remove
also some movies are not added to the library automatically I have to remove them and reload them into the media folder
