Macbook Pro 2016 CPU usage 100% temp. problem
server-mac
#1
Hi, I've recently bought a 2016 MBP 15", installed PMS and when playing a 1080p .mkv file the app use 100% of the CPU and the temp goes up to more than 90°C. The transcode setting is set to automatic. I would like to know if there is a way to maintain the best quality possible but limit the % of the cpu usage to something like 80-70% to obtain normal temperatures? The only way is lower the quality of the transcoding process?
Thanks.
#2
Check if you have thumbnails enabled in PMS Settings/Library , if so uncheck.
#3
I've disabled the thumbnails and now every 3 or 4 minutes the cpu goes to 100% but the temps stays under 80°, better but still a little bit high. Thanks.
#4
Are we looking at a large library?
Make sure your scheduled tasks are being executed at time the Macbook pro is active
#5
Yes, the library is large; but what do you mean by scheduled tasks?
Thanks.
#6
The schedule task now are being executed correctly but even without the thumbnail preview and the transcoding option to "high speed" the CPU pikes up to over 80°C.
There is a way to set PMS to use only 60/70% of the CPU power?
Thanks.
#7
James, just to be sure it not something else try the following.
Etrecheck, it will do a lot system check hardware and software. It's freeware and works a treat.
https://etrecheck.com/
#8
@Gdr56 said:
James, just to be sure it not something else try the folowing.
The report says "Performance: Excellent" and everything is ok. The laptop is brand new and works fine.
#9
Ok, that real good. Now that's out of the way, i will ask does this behavior occur when using handbrake to transcode a file from mkv to mp4?
#10
If I turn off the .mkv subtitles the pikes on the CPU disappears and the temps stay low. The problems are the built-in .srt subtitles in the .mkv file.
Is there something to solve this .srt transcoding issue??
Thanks.
#11
Thinking about this issue, your concern heat or CPU usage? Heat can be a concern so have a look at this freeware.
https://www.macupdate.com/app/mac/23049/smcfancontrol
I use it in the summer months in Australia on my iMac, works a treat. During transcoding with handbrake or running PMS if it needs to transcode.
If none of what I'm suggesting suits, what version of MacOS are you running with PMS. I personally don't see the persistent issues your suggesting. I'm on Sierra 10.12.6 with PMS 1.7.5.4035-313f93718
Possibles:
Malware or Virus
Short on Ram
High bit rate Transcoding
Subtities
#12
@james_911 said:
@Gdr56 said:
Ok, that real good. Now that’s out of the way, i will ask does this behavior occur when using handbrake to transcode a file from mkv to mp4?
Thanks.
You can use handbrake and remove the subs from the file if not required. Are your settings like attachment?
#13
Thanks.
Unfortunately I need the subs, I’ve tried removing the tracks that i don’t use with mkvtoolnix, tried the settings you suggested, tried with external .srt file; nothing works, as soon as i enable the subs the CPU goes from barely nothing to 100% and the temps from 45°C to more than 80°C. The problem is that when some subs are selected PMS redo the transcode of the file while playing it.
#14
@james_911 said:
Thanks.
Try Smc fan control then, crank up when playing those files.
Just curious to what are playing the file through, TV app or a player like Roku.
#15
I'm using "Macs Fan Control"; The client is a SONY kdl-50w808c tv.
Maybe I'll try posting the question in the Android TV section to see if the issue is fixable in some way.
#16
Have you transcoded the file to Mp4 I believe that may resolve your issue.
#17
Transcoding a single file with the PMS function require approx 35/40 min and for that time the CPU will stay always at full 100% usage. It's not worth it, for now I'll stay with my high temps and wait for some Android TV's app update...
