Make Plex accessible on LAN
server-linux
#1
Hello.
I want to be able to access my Laptop media files on my LAN, so I have installed Plex Server for that. I dont want my Plex Server in my laptop to be accessible outside of network so I have not enabled "Remote Access".
The problem is, for example the Plex client on my Android phone, always see my laptop Plex as offline. It can only access it if I enabled remote access.
My Phone and Laptop are both connected to the same network.
I found out than I cant even reach my Plex server while accessing via web browser from my phone, and I think its because my Plex Server is only listening on localhost interface in my laptop.
Here is the result of netstat command on my Laptop:
tcp 0 0 localhost:48124 localhost:32400 ESTABLISHED
tcp 0 0 localhost:32400 localhost:45788 ESTABLISHED
tcp 0 0 localhost:32400 localhost:48124 ESTABLISHED
tcp 0 0 localhost:45788 localhost:32400 ESTABLISHED
How can I make Plex listen on 0.0.0.0 instead of localhost?
Thank you.
#2
Plex Media Server does listen on 0.0.0.0
Do netstat -a -b or whatever is the equivalent on Linux
If you can get through remote access then maybe you have DNS Rebinding Protection for secure connections.
You could try with it disabled on the server network setting and on the client apps, select allow fallback to insecure connections
if it is that, then you could look into whitelisting plex.direct if the router allows configuration of the DNS Rebinding Protection setting
#3
The netstat report is for established connections but it is the LISTEN report that matters.
netstat -tulnp |grep -i listen
Maybe it would help if you mention the linux distro you are running. My guess is that a firewall is block access to port 32400.
#4
I am running Linux Mint 18.2
Plex appears in netstat report:
tcp 0 0 0.0.0.0:32400 0.0.0.0:* LISTEN 1623/Plex Media Ser
I can ping my PC just fine from my phone, but if I try to access the plex interface with :32400 in the browser I get a Connection timeout.
I think I dont have any firewall configured.
#5
Look into secure connections area. First see web setting in plex web app to try with allow fallback to insecure connections - bearing in mind that browser cannot have mixed mode so if one server connection is secure then all others must be as well.
Secure connections could be the issue if there is DNS Rebinding Prorection
#6
I found the issue. Somehow, I had iptables service active. I disable it and now it works.
