Master Buglist for Plex for Kodi.
plex-for-kodi
#1
In the hope that this client gets updated some day, here is some information regarding the bugs of the current Plex for Kodi client. Feel free to comment with suggestions / examples / log files.
Device - Odroid C2 running Raybuntu's LibreELEC-based Krypton V17 builds. (eMMC 8GB flash drive running OS)
AVR - Yamaha RX-V675 (5.1) via HDMI / CEC / ARC
Passthrough - AVR supports all codecs bar DTS:X / Dolby Vision. Enabled.
Burn Subtitles - Automatic
Local Quality - Original Quality
Remote Quality - Original Quality
FIXED ISSUES:
~~Movies that contain multiple parts do not seamlessly transition.~~ **FIXED.*
OUTSTANDING BUGS:
  • Upon leaving the add-on, 3 loading dots endlessly spin and does not return the Kodi homescreen. Force reboot required.
  • Switching between managed users causes crashes at least 80% of the time.
  • Add-on refuses to connect to the internet despite other addons display no issue i.e. HDHomerun yet returns later. SSL issue?
  • "Playback Failed!" - Inconsistent and impossible to reproduce on the fly. Just happens intermittently for me.
  • When pressing play on a stream, playback will not always start and sit on a orange background. Could be related to refresh rate switching.
  • When scrolling along On Deck and new items load in, the artwork next to the newly loaded show turns grey intermittently.
FEATURES YET TO BE IMPLEMENTED:
  • TV theme music.
  • Pre-roll Video and Trailers
  • Live Music Lyrics integration.
  • Plex Companion.
  • Label support.
  • Chapter support.
LIMITATIONS:
  • No Plex Companion support currently. Kodi remotes function as a workaround currently.
  • No Alexa support due to above.
#2
I'm with you, I'd love an update. Despite all of this, the Kodi version is still better than several other Plex apps.
#3
Agreed but let's keep this to bugs shall.we? There are plenty of discussion threads already.
#4
Device - Dedicated PC running LibreELEC official 8.1.0 generic x86/64 (60GB SSD for O/S)
AVR - Yamaha RX-V377 (5.1) via HDMI
Control - Harmony hub, remote & keyboard via bluetooth
Passthrough - Enabled.
PMS - Windows 10 64 bit using SMB paths
Never experienced this
100% of the time for me.
Again never experienced these.
Hadn't really noticed until today but yeah if scrolling through fast every 7th or 8th item is grey for a moment. Is this just caching? I just wonder because scrolling through the same list a second time and all images are loaded with no grey boxes.
#5
The most annoying bug for me is, that the audio gets out of sync. I think first this is due to framedrops which don't get properly synced up with audio.
I'm using an Odroid C2 @danjames92 do you also have those problems?
And I have another bug, I can't enter certain shows on the deck, they just won't open. However when I go to the library and pick it from there it works.
#6
I never had audio 'get' out of sync while watching something. But on multiple occasions, audio has been out of sync right from the start and I need to compensate with the audio offset. I know PFK is using the kodi player, but I can't help but wonder if sometimes something gets lost in translation.
I have not had this happen to me since I've started using PKC. May be just been lucky to this point.
#7
No sync issues here but I do use Raybuntu's build, not official LibreELEC. I also have av sync on my amp is switched on.
#8
Then I'm gonna try out the Raybuntu build
#9
I would. I found it vastly superior to LibreELEC.
#10
In what ways?
#11
@Pukinator said:
In what ways?
No GUI jumps when skipping forward, general patches to things like VC-1. Just look at the github patch notes for a better idea.
#12
OUTSTANDING BUGS:
    Both of these should be fixed in 0.1.0.
    I haven't had this issue. How reproducible is it? Hard to guess without logs what is happening.
    Hard to guess without logs.
    I haven't ever had this happen either.. logs would be helpful.
    Kodi limitation. Faster devices the problem is not as apparent. We do more artwork loading than likely any other addon ever and the pipeline is not optimized for this.
#13
While playing a video on Plex for Kodi on a Raspberry Pi with a Flirc V1 installed I encountered a bug. Sbout 20 seconds into a video, the video begins jumping back randomly by around 30 seconds, then jumps forward 15 seconds, then continues jumping back and forth in this loop until I stop the playback.
After stopping playback and starting the video again, it starts from where it jumped back to, but after around the 20 second mark, it happens again. The only solution is to remove the Flirc. I'm able to reproduce the issue consistently every time I attempt to play a video.
I've made sure there isn't ghost buttons. I covered the Flirc to make sure it wasn't picking anything up, I cleared the Flirc's remote configuration, and I hid the remote in the back of a drawer.
I've tried this on Recalbox 4.1 running Kodi 17.1 and LibreELEC 8.0.2.
#14
If you could make a new thread and include logs we can pinpoint the issue:
https://forums.plex.tv/discussion/246912/reporting-plex-for-kodi-issues#latest
