Match / Fix Incorrect Match Not Updating Metadata
server-linux
#1
First off, great product worth of my PlexPass Membership.
I am having issues with the matching. Where there will be a match made however in some cases it does not seem to overwrite the incorrect metadata. I have seen this happen with both music and movies.
For instance on an album that has incorrect names, it has found a match. I will click "Fix incorrect match". It finds a match that is correct. I click on it but the metadata remains the same.
Am I doing something wrong? Is there a setting I've missed?
#2
Did you find any solution for this problem? I even tried to play with the priority in Agents with no luck.
