Media Categories should use Library Names
When using any of the clients, I have multiple “Recently Added in Movies” headers, because I have multiple libraries that have movies in them. The web and app clients should use the library name. Or even better, a server side option to allow Library names to be used. This way, my home page might show;
Recently added in “Horror Movies”
The Ring, I know what you did Last Summer
Recently released in “Horror Movies”
Cabin in the woods
Recently added in “Family Movies”
Mitchel’s vs the Machines, Toy Story 3
–(where Horror Movies and Family Movies are the names of libraries) instead of –
Recently added in movies
Recently released in movies
Cabin in the woods
I’m a little confused… on what version of Plex is your server?
On my setup the hubs seem to be named like Recently Added in <library name>.
The only difference are hubs that are merged across libraries (e.g. Recently Released Movies, Recently Played Movies)
On the Settings > Manage > Libraries page, at the bottom is a checkbox labeled “Merge recently added items.” If that is enabled, then the ‘recently added’ items from all movie libraries will be combined into a single hub. Since items in that hub come from more than one library, it just says “Recently added movies.”
Yeah I run plex on another box. I guess I clicked update a while back and it was hung, Didnt say there was an update, but never restarted to update. I logged into the box directly and there was nag screen. I clicked okay and it updated and now I see what you see. Thanks
