mkv files always transcode when having 5-channel DTS or 5-channel Dolby Digital
windows-store-app
#1
This discussion was created from comments split from: Windows 10, no DTS audio.
#2
To be sure I have Server showing: 1.5.5.3634 as latest version (where you can check for newer).
I also have Window 10 as client with the Plex App from the Windows Store as well as the web front end of the server (on FreeNAS) which acts as the same as Plex App more or less.
I have continued to pound for answers but zero help.
Server winds up transcoding almost all content I have and stutters and complains. This is the case for MKV containers that have 5-channel DTS or 5-channel Dolby Digital.
This is a mess...there's no good reason why transcoding is happening, and the current server version doesn't even have an option to disallow transcoding. Direct Play options have no affect and Plex team seems apathetic on this issue.
I've had to resort to copying the files to my desktop and opening VLC to play them out with their native audio.
I don't want to hear "blame Microsoft" because Microsoft allows DTS, DD, and almost all lower formats of audio to play and multiple programs and applications exist which play fine under those codecs without throttling the system for transcoding.
But Plex's server or windows client applications don't seem to play well which ruins the entire Plex experience.
#3
I don't think we ever had any logs / diagnostics to see why it is happening.
The previous post you had about this back in March (https://forums.plex.tv/discussion/comment/1408314/#Comment_1408314) was when there were issues on FreeBSD transcode temporary directory access which were the subject of the forum topic you posted in
Could I suggest you provide the following,
A test carried out with debug logging enabled on the server
capturing server and windows plex app logs
and getting the media info for the mkv
and details of your HDMI connection setup
and if you could also try the same with Plex Media Player and see if it is different
For logs
For the Plex for Windows Store App logging, go to Settings within the app and select Advanced and ensure Logging is ON before you do the test
For Plex Media Server logging, goto server general settings and ensure debug logging is enabled
See https://support.plex.tv/hc/en-us/articles/201643703-Reporting-issues-with-Plex-Media-Server
Then select a sample file that you do not believe should be transcoded and play that
Collect the logs,
For Server logs, See https://support.plex.tv/hc/en-us/articles/200250417-Plex-Media-Server-Log-Files
For the windows app log, go to settings within the app then Advanced and select option Email diagnostics which will show where the diagnostics.zip is. Either email it to yourself to attach here or copy it out from the path shown
And please get the media info for the test mkv file
See
https://support.plex.tv/hc/en-us/articles/201998867-Investigate-Media-Information-and-Formats
Attach logs zips (server and app) plus the media info.
Could you also see if using Plex Media Player gives you what you want to achieve. Plex Media Player does its own encoding if needed and may Direct Play.
The download for Windows is available here https://plex.tv/downloads
Current version is 1.3.0
#4
@marcisikoff I have confirmation that there is no direct DTS support within the Windows Universal Platform (UWP) - see https://docs.microsoft.com/en-us/windows/uwp/audio-video-camera/supported-codecs
Your only option is to use Plex Media Player which does its own encoding when needed
#5
Just as a note for the future, it is always best to raise forum topics in the forums that relate to your application or server - rather than tag on by adding posts in unrelated forum topics - well related in some way but not the actual problem that you have
