[MOD] Studio Logos Color - 6000+
other-skins
#1
These will show up in webclient and more importantly pht. For some reason web client doesnt need the xml, which is handy if you dont want to edit xml all day long!
I took the color logos from xbmc/kodi Aeon NOX MOD - http://forum.kodi.tv/showthread.php?tid=157923
Respect to neurosis13 and ember media manager
Made the substitutions.xml, then replaced the /Studio folder in plugin - /Media-Flags.bundle
To make this stick you will need to change permissions on folder/xml, i just locked /Resources.
Guide:
Open plugins location
stop pms
overwrite /Studios
overwrite substitutuions.xml
backout to /Resources, right click it -> properties > security > edit > right click 'Administrators' > deny 'List folder contents' > deny 'Write' > apply > ok/yes to all > close
restart pms, enjoy
These logos are smaller than plex default but ok for me, if you want any adding upload logo in same size 161x109 png and i will eventually add or upload your own pack!
I used activestate TCL and http://www.sttmedia.com/filelistcreator to make list, basic code is:
#  Slurp up the data file
set fp [open "studlist.txt" r]
set file_data [read $fp]
close $fp
set fp [open "output.txt" w]
#split
set split_stud [split $file_data
foreach line $split_stud {
    set sline [expr [string length $line] - 5]
    set spline [string range $line 0 $sline]
    puts $fp ""
close $fp
put list in tcl /bin, open tclsh.exe, paste code in, add output to xml
tested on windows should work on nix just need to sort perms etc.!
https://www.dropbox.com/s/x5qiucwfsoy7qgw/studio-color.rar?dl=0
resized to larger plex but doesnt seem to matter
https://www.dropbox.com/s/kkhyiu1hsk6gpub/Studio.rar?dl=0
#2
#3
Guide:
stop pms
overwrite /Studios
restart pms, enjoy
Have added plex size logos!
close $fp
#split
    puts $fp ""
close $fp
plex size logos 512x288
This is pretty cool- was this done on a windows OS?
#4
hi yes, but is server side so should work on all os wherever server stores logos/xml
#5
hey thanks. i might give this a shot
#6
Good man :_), Plex will overwite the whole lot once you remove permissions, so if you dont like it it will vanish... :_)
#7
hey thats cool, then I will. Ill post a note once it's done. thanks a lot for your efforts!
#8
Hello! Cool!
Can help install this to Synology?
#9
Hello! Cool!
You need to connect via SSH to your Synology. Remember to login as Root (same password as your Admin).
If you are using a Windows Pc, then you can try to look at WinSCP (freeware) and connect to your Synology via SFTP
- Extract one of the above rar files.
- Stop PMS
- Navigate to "/volume1/Plex/Library/Application Support/Plex Media Server/Plug-ins/Media-Flags.bundle/Contents/Resources" - There you find the "Studio" folder and "substitutions.xml"
- Backup the "Studio" folder and "substitutions.xml"
- Upload and overwrite the "Studio" folder and "substitutions.xml"
- Start PMS
I hope this will help you forward :-)
#10
Any idea how to get this to work for FreeNAS installs?
#11
Im sorry, but I have no idea how to follow your guide. Am I suppose to make the files myself? You only link to all the logos, but there is no Studio or substitution files in the dropbox file you can download.
How exactly do I go about replacing the files, and where do I put the folder with all the studio logos?
I have a Mac Mini, not Windows. Can I even do it?
#12
error 404 on dropbox :( is possible a reup?
