Don’t do that.
Add only the parent movie folder.
Fix that and make sure everything is settled down before you move anything.
You can drill for genre or view by folder.
Don’t do that.
Thanks!
Correct.
You can add other parent folders, and other parent folders on other drives to the Library, but there is no need to add each folder in the parent… the parent has it covered.
Thanks!
… and MAKE SURE you don’t add any TV Show Folders for TV Show Libraries- Parent ONLY! <—not doing that will release the angry Kraken immediately.
Ok…you lost me. Who’s the angry Kraken and by adding TV Show Folders for TV Show Libraries? It’s all so very confusing.
This is my method: Hard drive 4T>TV (folder inside the hard drive) and inside that folder all my TV shows. And each series has it’s own folder.
Don’t add TV Show Folders - only add the parent TV Show library folders… like you are now doing with Movies. In a TV Show library adding TV Show Folders angers the Kraken immediately.
Thanks. I’m assuming the Kraken is admin?
The Kraken is the Plexisaurus, that shows no mercy to TV Show Folder Adders…
lol
What happens when admin doesn’t like what we do?
“Simplicity is difficult to achieve, yet worth the effort.” Paul Rand
If ur a guest of my server - all sorts of unpleasant things… ![]()
You are the admin of your Plexiverse. Don’t do things that the Plexisaurus doesn’t like doing and you’ll be fine.
You can confuse the beast at times… Collection Container Abuse Provides Genre Separation - Not Intended For Minors - or Wussies:
Nothing good happens without a work-around - and that’s the Mother of all of 'em…
