Movie metadata/posters not downloading.
server-freebsd
#1
I recently upgraded my NAS hardware and decided to build a new ZFS while adding a drive. I'm running FreeNAS, same as I was before. When creating my libraries the metadata and posters are no longer showing. I'm using the Plex movie scanner and have already unchecked/made low priority the local media options, too. I've tried analyzing, changing to TMDB and refreshing, but nothing seems to work. Never had this issue before. Happy to send my debug log if needed.
#2
Bumping this to the top. Any help is greatly appreciated. Happy to provide any info/logs needed.
#3
Try enabling VIMAGE in the jail settings if it isn't already, restart the jail then refresh the libraries.
#4
VIMAGE and autostart are both on.
#5
Does anyone have any ideas where I can look for the issue?
#6
This has come up before. Searching the forum should yield good results.
#7
I have been having the same issue. This post is what I managed to find, and it worked in my case.
#8
im facing the same problem, i have installed plex plugin with a plugin jail and plex pass with a standard jail, i configured two servers on Plex each for each jail and both dont add posters nor metadat, i have tried anything and yet cant get posters nor metadata and searched the internet for a fix with no luck till now, please anyone has an idea how this is fixed.
