Multiple EPG and channel matching bug, when EPG's use the same number
Choosing a channel in a second EPG does always revert to same channel number for the first EPG before saving. Tried with chrome and edge. So you can’t save the correct one.
Plex version: 1.24.3.5033
Having the exact same issue
It’s still happening on 1.25.6.5545 - one DVR with two (or more) EPG regions.
  1. “021 WDR Köln HD” EPG 2 in the dropdown reverts to → “021 Servus TV HD” EPG 1
Also, picking any station with identical numbering always reverts to the first one in line:
  1. EPG channels to choose: 050 Saarland / 050 Augsburg / 050 REGIO TV / 050 RheinLokal
    Picking “050 Augsburg” or "050 REGIO TV“ or "050 RheinLokal " turns into → „050 Saarland“.
Can the pre-written Plex EPG lists like “Giga TV Net” or “Vodafone TV” edited locally? Sorting over 1000 lines alphabetically would make manually matching very fast.
Edit: 1.25.6.5577 seems to fixed it for me. 1.25.7.5604 also working fine
Still getting this issue on 1.25.7.5604.
It recognizes that there is a secondary broadcast listing present, allows you to scroll and highlight channels from the secondary, but instantly reverts it back to the primary listing if the channel numbering matches. Can Plex be fixed so that multiple channels can hold the same channel number?
