Music scanner causes PMS to crash
An old topic, just same problem here. I’ve updated to the latest version as of Sep 1. 2018. PMS has been working for days updating meta data. after “Matching”, I’m seeing:
Uploading…
Error issuing curl_easy_perform(handle) 28
HTTP simulating 408 after curl timeout
Error parsing content
Error parsing XML
PMS just quits updating my library. I’ve attached my debug logs.
@chuckleamon
I moved your post here. That old thread is no longer applicable.
Please supply the typical information we need?
  1. Server version
  2. Where it’s running
  3. Log files (DEBUG) capturing the crash (which you appear to have)
Thanks @ChuckPa. After posting I noticed the original was regarding Linux and mine is not. So I started another topic.
[Plex Forum] PLEX scanner fails to retrieve data - parsing errors
Thanks for the heads up.
Chuck
