My plex keeps crashing every other day.. Does anyone else experience the same?
server-linux
#1
As above stated, my plex keeps crashing. I think it might have something to do with me watching from an Ipad, but that's just speculations.. Anyone else with the same problem, or eventually a fix?
tya
#2
If it is crashing there would be relevant info in the server logs
Please attach the logs here to be downloaded on restart after next crash
See
https://support.plex.tv/hc/en-us/articles/201643703-Reporting-issues-with-Plex-Media-Server
https://support.plex.tv/hc/en-us/articles/200250417-Plex-Media-Server-Log-Files
#3
This here should be my logs. It happens quite a lot
#4
Strange things showing up in the logs
  • on launch after a crash Plex Media Server first kills any residual processes from time before the launch. The logs show these accumulating with multiple processes being killed when only one should be there. As if the kill is not working and you do end up with multiple instances of processes
  • Server is seeing a lot of other servers. Are you on a big network a 10.0.xx.xx network rather than 10.0.8.xx ?
  • And the WAN IP for the server is being returned by the router as 127.0.0.1 !
Some extracts to show this
Server IP Address info
Aug 11, 2017 15:50:50.869 [0x7fbd12c40800] DEBUG - Network interfaces:
Aug 11, 2017 15:50:50.869 [0x7fbd12c40800] DEBUG -  * 1 lo (127.0.0.1) (loopback: 1)
Aug 11, 2017 15:50:50.869 [0x7fbd12c40800] DEBUG -  * 3 eth0 (10.0.9.8) (loopback: 0)
and server name is antaeus
Recorded public IP address in plex.tv is 185.21.xxx.xxx
But the router when interrogated returned 127.0.0.1 as the public IP address - how is that possible
Aug 11, 2017 14:50:17.804 [0x7f4299fff700] DEBUG - NAT: PMP::getPublicIP, Received public IP from router: 127.0.0.1
Aug 11, 2017 14:50:17.804 [0x7f4299fff700] DEBUG - PublicAddressManager: got WAN IP 127.0.0.1 from router
and the servers that are being seen are all these on 10.0.7.x and 10.0.9.xx - just wondering if that is actually your intention
Aug 11, 2017 14:50:14.544 [0x7f42953ff700] DEBUG - NetworkServiceBrowser: SERVER arrived: 10.0.9.29 (antaeus)
Aug 11, 2017 14:50:15.415 [0x7f42953ff700] DEBUG - NetworkServiceBrowser: SERVER arrived: 10.0.8.24 (FeralHosting Antaeus)
Aug 11, 2017 14:50:15.825 [0x7f42953ff700] DEBUG - NetworkServiceBrowser: SERVER arrived: 127.0.0.1 (antaeus)
Aug 11, 2017 14:50:15.965 [0x7f42953ff700] DEBUG - NetworkServiceBrowser: SERVER arrived: 10.0.8.119 (antaeus)
Aug 11, 2017 14:50:15.981 [0x7f42953ff700] DEBUG - NetworkServiceBrowser: SERVER arrived: 10.0.8.113 (antaeus)
Aug 11, 2017 14:50:15.996 [0x7f42953ff700] DEBUG - NetworkServiceBrowser: SERVER arrived: 10.0.9.16 (FH_Server)
Aug 11, 2017 14:50:16.015 [0x7f42953ff700] DEBUG - NetworkServiceBrowser: SERVER arrived: 10.0.8.74 (Cloud Server)
Aug 11, 2017 14:50:16.032 [0x7f42953ff700] DEBUG - NetworkServiceBrowser: SERVER arrived: 10.0.9.42 (antaeus)
Aug 11, 2017 14:50:16.050 [0x7f42953ff700] DEBUG - NetworkServiceBrowser: SERVER arrived: 10.0.8.96 (Séries TV, Antaeus)
Aug 11, 2017 14:50:16.069 [0x7f42953ff700] DEBUG - NetworkServiceBrowser: SERVER arrived: 10.0.9.38 (antaeus)
Aug 11, 2017 14:50:16.087 [0x7f42953ff700] DEBUG - NetworkServiceBrowser: SERVER arrived: 10.0.8.124 (antaeus)
Aug 11, 2017 14:50:16.119 [0x7f42953ff700] DEBUG - NetworkServiceBrowser: SERVER arrived: 10.0.9.21 (Minh)
Aug 11, 2017 14:50:16.137 [0x7f42953ff700] DEBUG - NetworkServiceBrowser: SERVER arrived: 10.0.7.123 (AO)
Aug 11, 2017 14:50:19.527 [0x7f42953ff700] DEBUG - NetworkServiceBrowser: SERVER arrived: 10.0.9.5 (antaeus)
and regarding the crashes - i need to understand what was happening
We have a set of logs that go up to Aug 11, 2017 02:45:28
The next log file starts at Aug 11, 2017 14:50:10 - so was there a crash after 02:45:28 that you noticed at 14:50 and restarted the server?
At 14:50 Plex Media Server found 42 residual processes from previous run and what is strange is that there 15 python com.plexapp.system processes, 6 Plex EAE Service processes and 10 Plex Tuner Service and on next relaunch these were still to be killed. So kill process is not working.
This shows the attempts to kill old processes at the 14:50 launch
This session lasted till Aug 11, 2017 15:50:37 and 9 seconds later there was a relaunch of Plex Media Server. Did you do that ?
And the old processes all but 4 were still there needing to be killed again
I am going to get a linux person pick this up
What is the platform? I see the linux version shows as
ubuntu PC x86_64 - build: linux-ubuntu-x86_64 ubuntu
Linux version: 4.12.4-feral (#2 SMP Sat Jul 29 19:17:51 BST 2017)
And one final question - why are you still on version 1.5.5 of Plex Media Server?
The current Public Releasde version is 1.7.5
Please could you look into my observations and issues highlighted and update the thread
#5
Moving the thread to the linux forum
#6
@marenodo
Would you please go to the host, open a Terminal (shell) window and type the following, capture all the text output, place in a file and attach here ?
sudo sh
/bin/df -m
ps -ef
ifconfig
netstat -an
free
ipcs
#7
Hi there, sorry for the late answer.
I do not have root acces. Or acces to sudo
#8
Then you need to ask the person in charge of the server to upgrade Plex to the latest version, check if the issue persists and if it does then ask him to perform the diagnostics that Chuck requires.
#9
There are serious issues on that environment if "kill process" does not work and has no permission to do that and to be on a class b network - is that wise ?
and to have many servers with the same name
and for the router to respond with a response indicating 127.0.0.1 is the public WAN IP Address - that is not right
I do not think the issue is the version of Plex Media Server but more, the environment that the server is running in - however, the upgrade should be done but in a sane environment and any issues should be raised by the server owner that has root access
#10
@sa2000 said:
There are serious issues on that environment if “kill process” does not work and has no permission to do that and to be on a class b network - is that wise ?
Feral uses network namespaces to run 1 instance of Plex per user. The kill command Plex seems to be issuing is attempting to kill processes owned by other users (and is rightly failing).
Feral has unique names for every host – but since they are using network name spaces and running multiple Plex processes per server, it may appear otherwise.
I believe that this is an artifact of the network name spaces. That’s the route out to the public internet from the private namepace.
The Feral servers are a sane environment, once you step back and look at the bigger picture.
#11
To bring closure here from your other threads. Debian is not officially supported. That kernel build and environment (Feral’s namespaces) is a YMMV (your mileage may vary) and isn’t supportable.
