MyCloud Home and TV Shows
Hi
I raised this issue with Western Digital but they referred me here.
Mycloud Home Plex as working fine all my movies, TV shows, Photos and music where all indexed - then an update messed it all up.
I re enabled Plex on the Mycloud Home and now my some of my TV shows are not showing at all - some of the ones that are have each season of a show showing as one episode with multiple versions - each “version” being an episode of the show.
Any way to correct this?
Yes, fixing it is fairly easy. Im going to bet your naming schema does not follow the plex format. See Naming and Organizing Your TV Show Files | Plex Support
My standard response to that is:
If you want to save yourself a lot of time I would recommend using Download - tinyMediaManager and use ${title} (${year}) {imdb-${imdb}} as the new name format.
Once thats done do a Plex Dance.
My structure hasn’t changed since it was working fine.
The Mycloud Home has a Plex Folder which has sub folders one of which is called Shared TV Shows.
I have each TV show in it’s own folder, which in turn contains a folder for each series which in turn has each episode of that series e.g. S01E01 etc
There doesn’t appear to be any way of splitting the “versions” back into the individual episodes and it is completely ignoring some shows entirely
Plex has dropped support for several naming schemas over the years. Just because your old non-standard format used to work doesnt mean it will continue to work.
overlapping shows/episodes need split at the show level. However fixing your naming schema is the better solution instead of trying to manually split stuff apart and manually matching them.
My naming schema worked until it didnt too. About 6 months ago plex dropped support for the [SSxEE] naming schema in order to allow people to hide stuff in file names using [ ]. About half my library disappeared before I caught it.
