Myplex Invalid Credentials
watch-later
#1
i recently switched my service to fios from comcast. i'm using fios router also. i forwared all the ports that are required. i'm able to log into myplex from the web but for some reason it's not working on my android or any other device. i keep getting invalid credentials please log in with correct. any help is appreciated. thank you.
#2
Got it fixed. Updated to newer android app and it worked fine.
#3
I am now getting a message "invalid Credentials" I can click on the start by Google an d it will work. Is there a fix for this.
thank you
