NEW FEATURE: Suggestion for clashing recording conflict resolving
Using the browser player to set recordings, you occasional get the modal popup for clashes. It would be nice to be able to resolve the conflict on this modal directly.
A mini timings guide would mean you can see the overlaps visually, add with it a drag and drop on each recording and you can then set the preferred priority order right there. You will still have a clash but at least can choose which recording would be best to sacrifice, for example 1 may clash with 2 recordings, so choosing to say loose an episode in a series may save 2 movies. More apparent when you start adding extra time to the start and end of all recordings (say 5 mins on both).
Mockup
