New Storage Same Show
I purchased a couple of new hard drives as I was running out of space. If I want to add episodes of a show that’s already in my library and save them to the new hard drives, do i just create the folder on the new hard drive and drop in the files and Plex will identify that it’s the same show? OR will it create another entry in the library for the same show since there’s 2 folders for it?
Even if it’s creating a separate show, you can always “Merge” them.
Ah excellent, thank you!
