No connection
server-mac
#1
I have the Plex server on MAC and I connect to it via Samsung TV.
I guess one of the software update made disconnection between the MAC and TV.
I'm not able to connect them anymore.
I have tried changing configuration but it didn't help.
The MAC and TV on the same network.
Any ideas?
#2
first a little more information please
what model of tv and version of plex on the tv?
and second what version of plex is on your sever?
If i had to guess i would say that your tv is having an issue getting a secure connection with your plex sever. if this is the case you can allow a insecure connection on your local network for your tv, and be back in business.
#3
The TV version is 3.0.10 (2.13.1)
The MAC Plex server version is 1.4.4.3495
I have follow the instruction and change to always insecure connection in the TV configuration settings.
Do i need to do something else?
#4
I am not familiar with that model of tv, however most tv with plex seem to have a place where you can put in the servers ip address. Have you tried that?
#5
I had the same problem as @noammaoz, and only noticed it in recent days. My setup:
Plex Media Server 1.4.4.3495 on OS X 10.9.5
Philips Smart TV
As updates 1.4.4.3495 and 1.4.3.3433 came within days of each other just this month, I had a feeling they were the cause of the problem. Thanks to a tip from @paulkeeley at this thread: https://forums.plex.tv/discussion/223300/osx-rollback-update I found a workaround to recover the "Content" folders of previous versions of Plex Media Server. So I tried rolling back to update 1.3.4.3285 (released Feb 10, 2017, I think?) which was around the last time I recall the setup working, and true enough, it did work! My TV is now able to detect the media server once again. \o/
So evidently, there may be some issue with 1.4.4.3495 (and 1.4.3.3433) that's causing this problem?
#6
Philips Smart TV
Good Information.
This is not occurring with my LG or Hisense TV app so Phillips and Samsung TV apps are affected by those updates>
#7
I hope you meant PMS settings rather than something in your TV settings.
Plex from in the Browser. Settings> Server> Network> Disable secure connections.
#8
Thanks for clarifying how that's done. But I tried it, and 1.4.4 still wouldn't work, so I guess I'm stuck with 1.3.4 for now…
