No metadata on fresh install
server-freebsd
#1
The mac that was running plex media server for me died, so I installed it in a jail on my freenas with pkg install plexmediaserver-plexpass. The server works great (even outside) except that no metadata at all is fetched from the internet. I tried all the different combinations of agents and scanners to no effect. This happens with movies, TV, and music. Music isn't even pulling artwork that's embedded in the files, let alone pulling from upstream.
uname -a
FreeBSD plex 10.3-STABLE FreeBSD 10.3-STABLE #0 r295946+07c41cd(9.10-STABLE): Wed Nov 9 00:19:25 UTC 2016 root@gauntlet:/freenas-9.10-releng/_BE/objs/freenas-9.10-releng/_BE/os/sys/FreeNAS.amd64 amd64
pkg info
apr-1.5.2.1.5.4 Apache Portability Library
bash-4.4.11 GNU Project's Bourne Again SHell
ca_root_nss-3.22.2 Root certificate bundle from the Mozilla Project
compat9x-amd64-9.3.903000.20161027 Convenience package to install the compat9x libraries
curl-7.48.0_1 Non-interactive tool to get files from FTP, GOPHER, HTTP(S) servers
cvsps-2.1_1 Create patchset information from CVS
db5-5.3.28_3 The Oracle Berkeley DB, revision 5.3
expat-2.1.0_3 XML 1.0 parser written in C
gdbm-1.11_2 GNU database manager
gettext-runtime-0.19.7 GNU gettext runtime libraries and programs
git-2.7.4_1 Distributed source code management tool
indexinfo-0.2.4 Utility to regenerate the GNU info page index
libffi-3.2.1 Foreign Function Interface
libidn-1.33_1 Internationalized Domain Names command line tool
p5-Authen-SASL-2.16_1 Perl5 module for SASL authentication
p5-Digest-HMAC-1.03_1 Perl5 interface to HMAC Message-Digest Algorithms
p5-Error-0.17024 Error/exception handling in object-oriented programming style
p5-GSSAPI-0.28_1 Perl extension providing access to the GSSAPIv2 library
p5-IO-Socket-IP-0.37 Drop-in replacement for IO::Socket::INET supporting IPv4 and IPv6
p5-IO-Socket-SSL-2.024 Perl5 interface to SSL sockets
p5-Mozilla-CA-20160104 Perl extension for Mozilla CA cert bundle in PEM format
p5-Net-SMTP-SSL-1.03 SSL support for Net::SMTP
p5-Net-SSLeay-1.72 Perl5 interface to SSL
p5-Socket-2.021 Networking constants and support functions
perl5-5.20.3_8 Practical Extraction and Report Language
pkg-1.9.4_1 Package manager
plexmediaserver-plexpass-1.3.3.3148 Plex Media Server component
python27-2.7.11_1 Interpreted object-oriented programming language
serf-1.3.8_1 Serf HTTP client library
sqlite3-3.11.1 SQL database engine in a C library
subversion-1.9.3_3 Version control system
wget-1.18_2 Retrieve files from the Net via HTTP(S) and FTP
#2
Figured it out. If the jail is running with VIMAGE unchecked, 127.0.0.1 stays with the host and the fact that plex has it hardcoded everywhere breaks scanning. Switched it to VIMAGE and disabled ipv6 (it's broken in jails on the version of freenas I'm sticking with) and it's scanning now.
#3
Thanks for the post. I also had to disable IPV6 in order for METADATA to populate on a fresh install.
So frustrating...
