Server Version#: 4.3.7.2
Player Version#: Apple TV Latest Version
Tuner Make/Model: HD Homerun Quatro
NAS:WD PR4100
Guide/Lineup name: DVR—Broadcast TV Boston (Manchester) OTA Broadcast
Just set up the HD homerun and Plex integration with an Apple TV as well as Plex Web client - 31 Channels, video looks good - EPG is working fine - I do not have any option to record any programs - If I click on a future program in the EPG I see the info for that program but thats it.
I do have Plex Pass - Just paid for it for the DVR functionality - It seems as if its not enabled - Tried restarting server as well as client - no luck
Typically I use an Amazon FireTV Stick 4K and recently acquired a TiVo 4K Stream stick which uses AndroidTV. With the FireTV and TiVo 4K Stream on the Plex guide grid simply highlight the show you wish to record and then hold down the button until a menu appears. The menu only has one option which is “Record”. So to record the selected show you would then press the button again or to abort press the back button.
I’m guessing the AppleTV would be similar but I can check,…
