Not matching shows based on tvdb id numbers
Server Version#:1.43.0.10492
Player Version#:N/A
The Plex scanner treats Scrubs (2001) {tvdb-76156} as the same show as Scrubs (2026) {tvdb-465690}. Showing the episodes as duplicates.
I temporarily moved scrubs 2001 to Classic TV and left scrubs 2026 in regular TV, but the meta data for the new one is wrong.
Make sure you place the year in the name of the
Folder
So scrubs 2026 on the new folder and scrubs 2001 on the old folder some say that it bit I found to also remove one of them if both are on the same drive do the scan and it should correct itself
As I said, the folders were named “Scrubs (2001) {tvdb-76156}” and “Scrubs (2026) {tvdb-465690}”. At any rate, I understand that keeping up the meta data and stuff is a huge task so I just manually edited the metadata on the new series.
