Nvidia Shield Remote Access
server-nvidia-shield
#1
For some reason, i have always had a bit of an issue with remote access. I seem to need the right combination of circumstances to get it just right. I just set up my server on my brand new Nvidia Shield. I set the Shield to a static IP, selecting the default IP it came up with. Then I deleted my existing port forward that was being used for my server when it was on my PC (and working correctly) and reentered a new port forward, using the same information, only changing the IP. What piece of the puzzle am i missing for this, seemingly finicky, Remote Access to work?
#2
It’s possible that my forwarded port is still closed. What other things could be keeping this from being used other than my router?
#3
When I activated remote access on my shield, I got the same problem. After I reboot the Shield, remote access was working properly.
Did you try to reboot your Shield?
#4
Or disable then re-enable remote access.
Also some times connection is not immediate. - 15-30 secs ish
#5
Did you enable using a manual port in PlexWeb?
