Nvidia Shield TV skin
other-skins
#1
Hey All,
I'm currently running a very old version of the plex client on my popcorn hour a-400, to which I love the layout however I'm needing to update the hardware.
Looking into the Nvidia Shield TV which looks to be the best hardware to currently run the client, however I'm not digging the layout/skin. You're unable to use a list view of the movies/tv shows, which i personally find annoying.
Is one able to update this feature/skin? If yes, does anyone have any examples you could show...thanks!!
Dave
#2
@dbeale83 said:
Hey All,
I’m currently running a very old version of the plex client on my popcorn hour a-400, to which I love the layout however I’m needing to update the hardware.
Looking into the Nvidia Shield TV which looks to be the best hardware to currently run the client, however I’m not digging the layout/skin. You’re unable to use a list view of the movies/tv shows, which i personally find annoying.
Is one able to update this feature/skin? If yes, does anyone have any examples you could show…thanks!!
Dave
You could always run Plex for Kodi or if u want the full Kodi look you could run MrMC on your Shield. They’re both head and shoulders above the default mess.
