transcoded media?
transcoded media?
No, the problem with out of sync subs is only if the movie is direct Streams/ direct played from server. (If I change plex connect sub settings to PMS the server will transcode and I have no problem with aug of sync subs)
I was not talking about the PMS being used to burn in subtitles in the transcoding step...
I would like to know, if the issue appears always with "resume" or only on media that needs transcoding (which can still use the PlexConnect subtitle renderer).
What kind of media did you replay when finding the issue: container, video/audio codec, subtitle format?
Remark: I tested with "aTV native data" (mp4, h264, aac) but could find the issue yet...
ok, sorry..
This is one example of video file with about 2-3 sec delay:
Subs: Extrenal .srt
General
Complete name : /******.mkv
Format : Matroska
File size : 5.46 GiB
Duration : 2h 14mn
Overall bit rate : 5 835 Kbps
Writing application : mkvmerge v4.1.1 ('Bouncin' Back') built on Jul 3 2010 22:54:08
Writing library : libebml v1.0.0 + libmatroska v1.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Format settings, GOP : M=4, N=32
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 14mn
Bit rate : 4 325 Kbps
Width : 1 280 pixels
Height : 536 pixels
Display aspect ratio : 2.35:1
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.263
Stream size : 3.94 GiB (72%)
Writing library : x264 core 140 r2377 1ca7bb9
Encoding settings : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=18 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=4325 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Audio
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 2h 14mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 1.41 GiB (26%)
Language : English
but this one is OK. ( same PMS / PlexCennect/ATV as above example)
General
Unique ID : *****
Complete name : /****.mkv (Pac)
Format : Matroska
File size : 8.74 GiB
Duration : 2h 11mn
Overall bit rate : 9 531 Kbps
Encoded date : UTC 2013-10-06 04:15:25
Writing application : mkvmerge v6.2.0 ('Promised Land') built on Apr 28 2013 12:22:01
Writing library : libebml v1.3.0 + libmatroska v1.4.0
Video
Format : AVC
Format settings, ReFrames : 4 frames
Duration : 2h 11mn
Bit rate : 8 024 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.161
Stream size : 7.18 GiB (82%)
Title : X264
Writing library : x264 core 133 r2334 a3ac64b
Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=18 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=8024 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Audio
Format : DTS
Codec ID : A_DTS
Duration : 2h 11mn
Bit depth : 24 bits
Stream size : 1.38 GiB (16%)
Title : DTS
Language : English
I have the exact same problem as described above: the exact same mkv+subs combo will play back fine on another Mac (Plex Home Theater), and resuming and/or fast forwarding isn't a problem. However, resuming the same mkv+subs on my 3rd gen Apple TV always results in the subs going out of sync. Plex server is running on a Mac Mini 2010, so should be fast enough to transcode just fine (playing back on the iOS Plex app, for example, results in no problems with subtitle sync). The HD files in question aren't particularly bitrate heavy.
Anyone who can confirm that this bug has been acknowledged?
Yep.
Same pb for me with resume and for/backward.>>Anyone who can confirm that this bug has been acknowledged?
Yep.
By the way, I noticed that the last subtitle is displayed forever, i.e long after the last dialogue has occured
Seen on mkv and srt files (all)
Not a big deal, but wanted to let it know
Bruno
Fixed.
Hello. I have my PSM at Nas Synology 713.
How can i update the subtitle file??
I dont find the forum for this.
Sorry form stupidity.
Enviado desde mi iPhone con Tapatalk
Baa.
Can you say me how update this file, please???
What do you mean with "update this file"?
I would guess bwynants pulled it all together into the Synology install package...
With the subtitle renderer forced to "iOS, PMS" the following will happen:
- MP4 with embedded subtitles will be played by your aTV without PMS activity (with or without subs displayed)
- everything else, eg. MP4 with external subtitle, MKV that need a transcoder swap, with subtitle to show, will force PMS to do a full transcode to burn the text to the video stream. That for sure will crank up your NAS. :-)
You should keep the Subtitle Renderer Setting at Auto - that way PlexConnect has a chance to have aTV deal with external subtitles (currently SRT only), removing the need for the full transcode on the NAS. Why did you change the Setting to "iOS, PMS"? Did you have new issues with the PlexConnect subtitle feature (well, I know some... :-)?
Y have proved to keep the subtitle renderer at "Auto" and dont work, Baa. The movie transcode on my Nas and the movie dont see.
The file I play is mkv with internal subtitles srt. Dont work.
My NAS is a Ds711+.
Have you got an idea Why dont play movies mkv with subtitule incrusted??
Thanks for your job, Baa.
PlexConnect can only catch _external_ SRT files. Embedded files (in MKV or wherever) can only be handled by PMS, which lead to a full transcode - as explained above.
I would like to get a log (loglevel=High, subtitle renderer=Auto) of...
- starting PlexConnect
- browsing to the movie
- selecting the subtitle
- staring replay
This might help in understanding, why your movie isn't be played in the first place.
Now, i understand you.
Thank you very much.
You have helped me.
Thanks.
Hi. I have a mp4 file with VOBSUB that has a constant ~2 second lag. Works fine in other iOS clients. I can share the file privately if needed.
According to your MediaInfo, the subs are embedded in the file - which means, it is played completely within iOS. Nothing for PlexConnect to do, not even the subtitles.
Just to make sure, you enable the subs while playing the movie with press&hold on the select button, right?
I just watched The Monuments Men and I have to thank you again for greenlighting this subtitles project, I would have missed so much in this movie. PlexConnect is amazing!!!!
