Opening Plex Experience Preview on my Chromebook kills PMS
I tried to use the Plex Experience Preview app on my Chromebook today. It would not open any content so I tried the regular app and the web interface and found that the media server was no longer online. After restarting Plex Media Server, I opened Plex Experience Preview and again the server went offline.
I did it a third time to confirm and the server app just disappeared from my PC the moment I tried to open anything after the home screen on the Plex Experience Preview for Android.
Same here. Open plex preview on pixel is working, but choosing something in the app make the Windows PMS crash immediately.
Same error. In my case when using the apk on PC with emulator
Is there a release for Chromebook already? Or for emulated platforms? Wow, just found out it doesn’t run on my refrigerator.
ok schlauberger. what about the same issue on my pixel 9 with the android preview?
Then you probably should have led with that. And name-calling in German is still name-calling.
Same here. Reported with logs in another post.
Plex App on Chromebook, which has always worked in the past is not working. Crashes when I try to load, so I downloaded the Preview and that works fine on the Chromebook for me. Prior to the issues with the regular app on Chromebook, I had downloaded the preview for my Android phone that sits alongside the regular app on there and both those are fine. Does Chromebook just need to put out an update or do I. We’d to fix something?
Latest Chrome OS update after 3 weeks fixed my problem so must have been an issue on their end.
