Original (?) Plex skin, but with more rows for movies and TV shows?
other-skins
#1
Been a Plex user for a long time. Mostly didn't touch anything (except Plex Pass updates) because when I set it up it was great.
My hard drive bit the dust, and while I generally have backups, it never occurred to me to backup my HTPC. So I had to do a fresh install of Plex.
I used to have the original Plex skin I think (the one the software ocmes with) because everything used to look like the default not like any of the skins, but now Plex shows me only TWO rows of "posters" on my Plex Theatre screen, where before I had at least 4. For the life of me I can't find a setting to put that back there (I don't want list - I want posters).
I cycled through a bunch of skins I downloaded thinking I may have installed something, but alas. Any ideas?
Also a suggestion I guess if I am wrong and halucinating ;) ... for the next release of standard Plex - give us the option of having more rows.
#2
*edit Plex Dark skin allows for 3 rows, but everything else on that skin bugs me ;(.
#3
What is dark skin? Plextra might have what you want.
Im sure in default skin you can change to large or small posters?
If all else fails delete guisettings.xml in pht home system dir
#4
Thanks \0 - deleting guisettings automatically brought back what I had. No idea how that happened. Again thanks for the help!
