I'm on a iMac mini Server but I'm not running an OSX Server, I'm running an OSX 10.8.3
PlexConnect : Press ENTER to shut down.
DNSServer : Failed to create socket on UDP port 53: [Errno 48] Address already in use
PlexConnect : DNSServer not alive. Shutting down.
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
launchd 1 root 11u IPv4 0xbfccbb72fa5e6e59 0t0 UDP localhost:60762
launchd 1 root 21u IPv4 0xbfccbb72fa5e6cd1 0t0 UDP *:137
launchd 1 root 22u IPv4 0xbfccbb72fa5e6b49 0t0 UDP *:138
launchd 1 root 23u IPv6 0xbfccbb7303b5ed81 0t0 TCP *:625 (LISTEN)
launchd 1 root 24u IPv4 0xbfccbb7303b64d69 0t0 TCP *:625 (LISTEN)
launchd 1 root 31u IPv6 0xbfccbb7303b5e9a1 0t0 TCP localhost:631 (LISTEN)
launchd 1 root 32u IPv4 0xbfccbb7303b64631 0t0 TCP localhost:631 (LISTEN)
UserEvent 11 root 106u IPv4 0xbfccbb72fa5e4379 0t0 UDP *:*
configd 17 root 11u IPv6 0xbfccbb72fa5e69c1 0t0 UDP *:*
configd 17 root 16u IPv4 0xbfccbb72fa5e58e9 0t0 UDP *:*
configd 17 root 20u IPv4 0xbfccbb72fa5e4999 0t0 UDP *:*
configd 17 root 22u IPv4 0xbfccbb72fa5e4811 0t0 UDP *:*
configd 17 root 24u IPv4 0xbfccbb72fa5e4689 0t0 UDP *:*
configd 17 root 27u IPv6 0xbfccbb730baf2e59 0t0 ICMPV6 *:*
named 19 root 20u IPv4 0xbfccbb7303b637c1 0t0 TCP localhost:53 (LISTEN)
named 19 root 21u IPv4 0xbfccbb7303b63ef9 0t0 TCP localhost:54 (LISTEN)
named 19 root 22u IPv4 0xbfccbb7307e22d69 0t0 TCP 192.168.1.121:53 (LISTEN)
named 19 root 512u IPv4 0xbfccbb72fa5e66b1 0t0 UDP localhost:53
named 19 root 513u IPv4 0xbfccbb72fa5e6529 0t0 UDP 192.168.1.121:53
syslogd 24 root 13u IPv4 0xbfccbb72fa5e4501 0t0 UDP *:64227
mDNSRespo 37 _mdnsresponder 8u IPv4 0xbfccbb72fa5e63a1 0t0 UDP *:5353
mDNSRespo 37 _mdnsresponder 9u IPv6 0xbfccbb72fa5e6219 0t0 UDP *:5353
mDNSRespo 37 _mdnsresponder 17u IPv4 0xbfccbb72fa5e2af9 0t0 UDP *:51999
mDNSRespo 37 _mdnsresponder 29u IPv6 0xbfccbb72fa5e5141 0t0 UDP *:51999
mDNSRespo 37 _mdnsresponder 38u IPv4 0xbfccbb72fa5e3bd1 0t0 UDP *:60446
mDNSRespo 37 _mdnsresponder 39u IPv6 0xbfccbb73047f64d9 0t0 UDP *:60446
mDNSRespo 37 _mdnsresponder 40u IPv4 0xbfccbb72fa5e5451 0t0 UDP *:49287
mDNSRespo 37 _mdnsresponder 41u IPv6 0xbfccbb73047fab49 0t0 UDP *:49287
mDNSRespo 37 _mdnsresponder 44u IPv4 0xbfccbb73047fa9c1 0t0 UDP *:54679
mDNSRespo 37 _mdnsresponder 45u IPv6 0xbfccbb73047fa839 0t0 UDP *:54679
mDNSRespo 37 _mdnsresponder 46u IPv4 0xbfccbb73047fa6b1 0t0 UDP *:60259
mDNSRespo 37 _mdnsresponder 47u IPv6 0xbfccbb73047fa529 0t0 UDP *:60259
mDNSRespo 37 _mdnsresponder 48u IPv4 0xbfccbb73047fa3a1 0t0 UDP *:56867
mDNSRespo 37 _mdnsresponder 49u IPv6 0xbfccbb73047fa219 0t0 UDP *:56867
mDNSRespo 37 _mdnsresponder 50u IPv4 0xbfccbb73047fa091 0t0 UDP *:61000
mDNSRespo 37 _mdnsresponder 52u IPv6 0xbfccbb73047f9f09 0t0 UDP *:61000
mDNSRespo 37 _mdnsresponder 53u IPv4 0xbfccbb73047f9d81 0t0 UDP *:55964
mDNSRespo 37 _mdnsresponder 54u IPv6 0xbfccbb73047f9bf9 0t0 UDP *:55964
mDNSRespo 37 _mdnsresponder 55u IPv4 0xbfccbb73047f9a71 0t0 UDP *:62809
mDNSRespo 37 _mdnsresponder 56u IPv6 0xbfccbb73047f98e9 0t0 UDP *:62809
mDNSRespo 37 _mdnsresponder 57u IPv4 0xbfccbb73047f9761 0t0 UDP *:58216
mDNSRespo 37 _mdnsresponder 58u IPv6 0xbfccbb73047f95d9 0t0 UDP *:58216
mDNSRespo 37 _mdnsresponder 59u IPv4 0xbfccbb73047f9451 0t0 UDP *:65384
mDNSRespo 37 _mdnsresponder 60u IPv6 0xbfccbb73047f92c9 0t0 UDP *:65384
mDNSRespo 37 _mdnsresponder 61u IPv4 0xbfccbb73047f9141 0t0 UDP *:54318
mDNSRespo 37 _mdnsresponder 62u IPv6 0xbfccbb73047f8fb9 0t0 UDP *:54318
mDNSRespo 37 _mdnsresponder 63u IPv4 0xbfccbb73047f8e31 0t0 UDP *:54226
mDNSRespo 37 _mdnsresponder 64u IPv6 0xbfccbb73047f8ca9 0t0 UDP *:54226
mDNSRespo 37 _mdnsresponder 66u IPv4 0xbfccbb72fa5e4b21 0t0 UDP *:54526
mDNSRespo 37 _mdnsresponder 67u IPv6 0xbfccbb72fa5e6091 0t0 UDP *:54526
mDNSRespo 37 _mdnsresponder 70u IPv4 0xbfccbb72fa5e24d9 0t0 UDP *:50072
mDNSRespo 37 _mdnsresponder 71u IPv6 0xbfccbb72fa5e2351 0t0 UDP *:50072
mDNSRespo 37 _mdnsresponder 72u IPv4 0xbfccbb72fa5e27e9 0t0 UDP *:57925
mDNSRespo 37 _mdnsresponder 73u IPv6 0xbfccbb72fa5e2041 0t0 UDP *:57925
locationd 41 _locationd 4u IPv4 0xbfccbb72fa5e52c9 0t0 UDP *:*
blued 53 root 4u IPv4 0xbfccbb72fa5e5f09 0t0 UDP *:*
apsd 56 root 9u IPv4 0xbfccbb730d3cf631 0t0 TCP 192.168.1.121:51438->17.149.32.31:443 (ESTABLISHED)
netbiosd 76 _netbios 3u IPv4 0xbfccbb72fa5e6b49 0t0 UDP *:138
netbiosd 76 _netbios 4u IPv4 0xbfccbb72fa5e6cd1 0t0 UDP *:137
SystemUIS 171 mitcha 8u IPv4 0xbfccbb72fa5e5bf9 0t0 UDP *:*
NetworkBr 176 mitcha 5u IPv4 0xbfccbb72fa5e3429 0t0 UDP *:*
NZBVortex 220 mitcha 5u IPv4 0xbfccbb7303b62951 0t0 TCP localhost:9483 (LISTEN)
Google 333 mitcha 90u IPv4 0xbfccbb730be307c1 0t0 TCP 192.168.1.121:52517->ye-in-f95.1e100.net:443 (ESTABLISHED)
Google 333 mitcha 96u IPv4 0xbfccbb730ca5d539 0t0 TCP 192.168.1.121:52428->edge-star-ecmp-01-lga1.facebook.com:80 (ESTABLISHED)
Google 333 mitcha 125u IPv4 0xbfccbb730d62ed69 0t0 TCP 192.168.1.121:52459->sin04s02-in-f24.1e100.net:443 (ESTABLISHED)
Google 333 mitcha 140u IPv4 0xbfccbb730d400631 0t0 TCP 192.168.1.121:52513->c9111f28.akamai.rjo.virtua.com.br:80 (ESTABLISHED)
Google 333 mitcha 148u IPv4 0xbfccbb730ca4bd69 0t0 TCP 192.168.1.121:49226->gh-in-f125.1e100.net:5222 (ESTABLISHED)
Google 333 mitcha 152u IPv4 0xbfccbb730ca7fef9 0t0 TCP 192.168.1.121:52457->200.172.62.55:443 (ESTABLISHED)
Google 333 mitcha 153u IPv4 0xbfccbb730d3c4219 0t0 TCP 192.168.1.121:52105->200.172.62.24:443 (ESTABLISHED)
Google 333 mitcha 161u IPv4 0xbfccbb730d3bc3a9 0t0 TCP 192.168.1.121:52502->gru03s06-in-f26.1e100.net:443 (ESTABLISHED)
Google 333 mitcha 174u IPv4 0xbfccbb730ca61d69 0t0 TCP 192.168.1.121:52441->a23-61-143-139.deploy.akamaitechnologies.com:80 (ESTABLISHED)
Google 333 mitcha 177u IPv4 0xbfccbb730d3bd219 0t0 TCP 192.168.1.121:52514->c9111f28.akamai.rjo.virtua.com.br:80 (ESTABLISHED)
Google 333 mitcha 187u IPv4 0xbfccbb730d3bf631 0t0 TCP 192.168.1.121:50874->channel-ecmp-06-frc1.facebook.com:80 (ESTABLISHED)
Google 333 mitcha 189u IPv4 0xbfccbb730ca9aef9 0t0 TCP 192.168.1.121:52111->gru03s08-in-f21.1e100.net:443 (ESTABLISHED)
Google 333 mitcha 192u IPv4 0xbfccbb730ca4aef9 0t0 TCP 192.168.1.121:52515->c9111f28.akamai.rjo.virtua.com.br:80 (ESTABLISHED)
Google 333 mitcha 194u IPv4 0xbfccbb730d3cbc71 0t0 TCP 192.168.1.121:52516->edge-star-ecmp-01-lga1.facebook.com:80 (ESTABLISHED)
Google 333 mitcha 197u IPv4 0xbfccbb730bb4dae1 0t0 TCP 192.168.1.121:52469->gru03s06-in-f25.1e100.net:80 (ESTABLISHED)
Google 333 mitcha 204u IPv4 0xbfccbb730ca9bd69 0t0 TCP 192.168.1.121:52473->gru03s06-in-f25.1e100.net:80 (ESTABLISHED)
Google 333 mitcha 212u IPv4 0xbfccbb730d3c57c1 0t0 TCP 192.168.1.121:52483->gh-in-f95.1e100.net:80 (ESTABLISHED)
Google 333 mitcha 217u IPv4 0xbfccbb730d3fe219 0t0 TCP 192.168.1.121:52484->gh-in-f95.1e100.net:80 (ESTABLISHED)
Google 333 mitcha 222u IPv4 0xbfccbb7307e21ef9 0t0 TCP 192.168.1.121:52486->gru03s06-in-f26.1e100.net:80 (ESTABLISHED)
Google 333 mitcha 227u IPv4 0xbfccbb730d3af3a9 0t0 TCP 192.168.1.121:52491->gru03s06-in-f26.1e100.net:80 (ESTABLISHED)
Google 333 mitcha 231u IPv4 0xbfccbb730d3bcae1 0t0 TCP 192.168.1.121:52494->a23-61-145-224.deploy.akamaitechnologies.com:80 (ESTABLISHED)
Google 333 mitcha 233u IPv4 0xbfccbb730d3a9539 0t0 TCP 192.168.1.121:52495->gru03s06-in-f26.1e100.net:80 (ESTABLISHED)
Google 333 mitcha 235u IPv4 0xbfccbb730d3ac089 0t0 TCP 192.168.1.121:52500->a23-61-145-224.deploy.akamaitechnologies.com:443 (ESTABLISHED)
Plex\x20M 775 mitcha 27u IPv4 0xbfccbb730d3b17c1 0t0 TCP *:32400 (LISTEN)
Plex\x20M 775 mitcha 53u IPv4 0xbfccbb72fa5e3ee1 0t0 UDP *:32414
Plex\x20M 775 mitcha 59u IPv4 0xbfccbb73047facd1 0t0 UDP *:32410
Plex\x20M 775 mitcha 60u IPv4 0xbfccbb72fa5e3739 0t0 UDP *:32413
Plex\x20M 775 mitcha 61u IPv4 0xbfccbb72fa5e3119 0t0 UDP localhost:53276
Plex\x20M 775 mitcha 62u IPv4 0xbfccbb72fa5e5761 0t0 UDP 192.168.1.121:54927
Plex\x20M 775 mitcha 63u IPv4 0xbfccbb72fa5e2c81 0t0 UDP localhost:63264
Plex\x20M 775 mitcha 64u IPv4 0xbfccbb73047f8b21 0t0 UDP 192.168.1.121:52028
Python 780 mitcha 12u IPv4 0xbfccbb7307e1fae1 0t0 TCP *:50641 (LISTEN)
Plex\x20D 781 mitcha 12u IPv4 0xbfccbb730d3bbc71 0t0 TCP localhost:50642->localhost:50641 (CLOSE_WAIT)
Plex\x20D 781 mitcha 14u IPv4 0xbfccbb72fa5e6839 0t0 UDP *:1900
Plex\x20D 781 mitcha 17u IPv4 0xbfccbb730d3a9c71 0t0 TCP *:1444 (LISTEN)
Plex\x20D 781 mitcha 20u IPv4 0xbfccbb72fa5e2f91 0t0 UDP *:2389
Plex\x20D 781 mitcha 23u IPv4 0xbfccbb730d601219 0t0 UDP *:7867
Plex\x20D 781 mitcha 26u IPv4 0xbfccbb73047f6c81 0t0 UDP *:7992
Plex\x20D 781 mitcha 30u IPv4 0xbfccbb730d3cc3a9 0t0 TCP *:32469 (LISTEN)
Plex\x20D 781 mitcha 34u IPv4 0xbfccbb72fa5e4ca9 0t0 UDP *:63983
Plex\x20D 781 mitcha 39u IPv4 0xbfccbb72fa5e2661 0t0 UDP *:60377
Plex\x20D 781 mitcha 47u IPv4 0xbfccbb72fa5e2971 0t0 UDP 192.168.1.121:56826->192.168.1.1:5351
Plex\x20D 781 mitcha 53u IPv4 0xbfccbb72fa5e3ee1 0t0 UDP *:32414
Plex\x20D 781 mitcha 54u IPv4 0xbfccbb730bb4e219 0t0 TCP localhost:32400->localhost:50636 (TIME_WAIT)
Cubby 812 mitcha 28u IPv4 0xbfccbb730bb4e951 0t0 TCP 192.168.1.121:50779->69.25.30.62:443 (CLOSED)
Cubby 812 mitcha 29u IPv4 0xbfccbb730ca073a9 0t0 TCP 192.168.1.121:50780->64.94.18.148:443 (ESTABLISHED)
Cubby 812 mitcha 33u IPv4 0xbfccbb730ca7f7c1 0t0 TCP 192.168.1.121:50782->mvx-201-76-183-78.mundivox.com:59123 (SYN_SENT)
Cubby 812 mitcha 35u IPv4 0xbfccbb7303b60c71 0t0 TCP 192.168.1.121:50781->69.25.30.44:443 (CLOSED)
Cubby 812 mitcha 37u IPv4 0xbfccbb72fa5e4e31 0t0 UDP 192.168.1.121:63795
server:PlexConnect-XML_templates mitcha$
Can anyone know what could be this error !?!
