I’m new to Plex and looked up the forums a bit but wasn’t able to find what I’m looking for.
If it’s just because I’m too dump then forgive me.
However:
I ripped all Star Wars: The Clone Wars (the Toy Story like 3D animation version of the series) to mkv files.
As some of you might know the epidoes aired in a chronological wrong order. Unfortunately this “wrong order” was used on the DVD release as well as for the sources that Plex uses for scraping.
So s01e01 from the DVD is s03e02 if I’m sorting it right (for example) so …
I used to create nfo files for KODI but that doesn’t seem to work for Plex. Any suggestions?
push
No one has an answer or at least a link for me to look up myself?
This is the only thing pretending me from using PLEX atm.
preventing*
Find a metadata source that have the order you want then an agent for it. The problem is as you say all sources are wrong, then no agent will sort that…
The scanner is responsible for selecting the season and episode number. I did write a scanner that can map absolute numbering anime series with tvdb season numbering on the fly, but you want funky stuff.
IF and only IF the tvdb absolute numbering is normal [forums.thetvdb.com/viewtopic.php?t=28261&start=10] then you can use an absolute tvdb agent and get this sorted
Otherwise, respect tvdb numbering and print a list with the right file order.
