Partial Metadata Download
server-freebsd
#1
I'm having a weird issue. I have The Real Ghostbusters cartoon. The initial scan didn't name everything correctly, because I didn't have the right naming convention used. I renamed the files using the plex naming convention, unmatched the files and scanned them. Plex was able to figure out the season and episode number & added the aired date, but will not pull down art work, voice actors, titles or anything else. I have worked on and off for 2 weeks and haven't been able to resolve the issue. Hopefully some one has had a similar problem and has figured out how to fix it.
#2
I'm having this same issue now. Did you ever find a solution
#3
Same problem, there are several threads for this already...
#4
Did any of guys get a resolution to this issue? I’m having the same problem.
