I tried the “plex dance”, several times : it had no effect on this issue.
Then I tried to deleted my photos library and add a new one… even with a new one, the timeline is messed up !
Not the same mix up than the previous library, but not OK either.
The most recent photos are in the right place, but the more you go back in time in the timeline, the more photos are shown under a wrong date.
It’s been a month since I posted the first message, is anyone from the plex staff even reading this ?
I guess it’s much more important to have a nice, shiny and BUGFREE library for all the movies that some people download illegally, than a functionnal library for the family pictures et the memories of our lives
it works fine for me, if i delete and re-add the photo library. but randomly comes back shortly afterwards on its own. or if i restore plex folder then run scans it comes back immediately .
the below 2 lines of log files seem to be the time at which it was triggered. if i run analyze on a photo library that was already analyzed and it just scans then timeline is fine. but below is an example of when i run analyze and it decides for some reason they need updated. then it screws it up. but some times i ran analyze and it don’t feel the need to update the files and the results is timeline continues to work.
Feb 14, 2022 16:29:39.446 [1968] DEBUG - HubCache: Expiring ‘1/photo.recent.21/1/hubs/promoted/enexternal-media,indirect-media/contentDirectoryID=21&count=12&excludeContinueWatching=1&excludeFields=summary&includeGames=1&includeLibraryPlaylists=1&includeMeta=1&includeRecentChannels=1&includeStations=1&pinnedContentDirectoryID=9%2C13%2Cplaylists%2C21%2C3%2C4%2C2%2C5%2C6%2C7%2C8%2C15%2C11%2C12%2C14%2C16%2C10’ because event plex.event.item.updated referenced an item the hub contained
Feb 14, 2022 16:30:41.803 [8180] DEBUG - Updating metadata item (save) (2009-02-12_) with ID 62160
i made an app, that updates the file name to the date of your choosing. also changes the all the date fields in the meta data to that same date. hoping this would make it easier on plexs ai to determine the correct date.
this is the oldest article i can find on plex forums but i think reddit has older ones.
i have deleted and rebuild photo library dozens of times trying different scenarios to see if there is only certain folders or files needed. but it seems you need the entire plex server folder for photos to work temporarily .
like others have said it is plex keeping a record of times/stamps/hash of each photo. if you have wrong info before and it scans it then your done in the future.
strange thing is. when you delete the photo library and add it back. its perfect. so what ever combo scanning method they use works fine.
BUT when you run analyze (sometimes) it messed it up and try’s to update certain photos and then the timeline is screwed up.
the funny thing is. this is a feature for plex pass customers, EVEN though i am, i have it turned off, AND it still has the nerve to send my photos to a third party and in return DISABLE functionality of my photos. All because i paid to be a plex pass customer.
I agree totally. think about it, everyone has smartphone. and they use it more for pictures than music and movies, but yet its on the bottom of there priority list. if they wouldn’t send it to a third party for analyze and use the built local scanner it would be fine.
There is a setting in the photo library named “Tag photos” which is supposed to control whether photo thumbnails are sent off to a third party. Do you have that disabled?
Same issue since I used plex years ago, and problem is lasting now (server version: 1.25.5.5492 on debian bullseye / plex web version: 4.69.1).
This problem may concerned with the bug: [BUG Identified] Photos Library - Photo Library Timeline Not Working - #13 by ben-page
because wrong date issue occurs on older photos rather than newer photos.
And analizing library was not solved the issue.
I hope to fix this bug, really… TIMELINE IS CRITICALLY UN-USABLE.
