playing fails with MF_MEDIA_ENGINE_SRC_NOT_SUPPORTED 0xc00d36b2
windows-store-app
#1
I have a synced video that fails with this error when I play it in the plex app. When I copy the original file and play with Windows Movie & TV it plays fine. According to this thread, it's due to EAC3 encoding and there are some pretty hacky workarounds. Is there a permanent fix or a Plex team sanctioned workaround that can be used (and that is permanent so that it survives across upgrades)?
#2
Same problem here with w10 app, if you try the webversion, plex.tv there it will give an other message.
Mine had to do with sotrage even direct play transcodes files to make them smaller to transfer.
after i resolved that issue i cloud play videos again
