Playlist library empty
plex-web
#1
The playlist page is empty and there are multiple errors thrown. I checked if they were being reported via sentry and I just keep seeing a 429 so I’m not sure if the error got reported to you guys before I was rate limited.
#2
Are you using https://app.plex.tv/desktop ?
I am not able to repo here. Do you have any playlists already? Or no playlists on the sever?
Could you share your XML response from /playlists to this server with me?
#3
Yes
I have 2 playlists added
Where would I find that? I tried a URL like __IP__.plex.direct:32400/libarary/playlists?&X-Plex-Token=__TOKEN__ but nothing.
#4
__IP__.plex.direct:32400/playlists?&X-Plex-Token=__TOKEN__
Unfortunately the error doesn’t give me a whole lot to go on. Right now my hunch is bad data from PMS but can’t be sure.
#5
That’s not the error what I was asking is does that URL look similar to the page I should be checking for the XML? There’s no option in the UI to see the XML for the playlist library.
#6
The url I provided should lead you to some raw XML, this XML is what is used to build the playlists page.
My hunch right now is the server is sending some bad data, but again, I am not able to reproduce this issue and haven’t seen any other reports of such an issue.
Clearly something is broken, I just need more information to diagnose the issue
#7
Is there anything else I can provide?
Should I enable debug logging and then try going to that playlist library?
#8
No, unfortunately logging won’t help in this particular situation. If you can share the XML response from http://SERVER_IP:32400/playlists?-X-Plex-Token=TOKEN that will eliminate a PMS issue and I can start down other paths where the issue might be.
#9
I do have one question: What PMS version are you using and what Web App version you using?
#10
That page returns a completely empty response. Even tried using curl and same result.
Plex web Version 3.39.3
Plex Media Server Version 1.12.0.4829
#11
Is it possible you have your PMS set to “Secure Connections Only”? If so could you set to to “Preferred” https://support.plex.tv/articles/206225077-how-to-use-secure-server-connections/
The fact that you say the page returns a blank page makes me suspect it is rejecting an http connection
› curl "http://127.0.0.1:32400/playlists?X-Plex-Token=TOKEN"
<?xml version="1.0" encoding="UTF-8"?>
<MediaContainer size="39">
<Playlist ratingKey="42165" key="/playlists/42165/items" guid="com.plexapp.plugins.itunes://E99F7BAD2076A247" type="playlist" title="90’s Music" summary="" smart="1" playlistType="audio" composite="/playlists/42165/composite/1511204658" icon="playlist://image.smart" viewCount="2" lastViewedAt="1511204730" duration="343319000" leafCount="1349" addedAt="1511204658" updatedAt="1511204658">
</Playlist>
<Playlist ratingKey="42168" key="/playlists/42168/items" guid="com.plexapp.plugins.itunes://E99F7BAD2076A247" type="playlist" title="90’s Music" summary="" smart="1" playlistType="audio" icon="playlist://image.smart" viewCount="2" lastViewedAt="1511204730" leafCount="0" addedAt="1511204730" updatedAt="1511204730">
</Playlist>
<Playlist ratingKey="42131" key="/playlists/42131/items" guid="com.plexapp.plugins.itunes://C39431B849A13659" type="playlist" title="My Top Rated" summary="" smart="1" playlistType="audio" composite="/playlists/42131/composite/1511204658" icon="playlist://image.smart" viewCount="1" lastViewedAt="1511204730" duration="46743000" leafCount="179" addedAt="1508800362" updatedAt="1511204658">
</Playlist>
For reference this is few lines of the response when I request it from my local dev server.
Since you are the only user that has reported this issue and I’m not seeing any similar errors in Sentry my only hunch right now is there is bad data being served from PMS.
I doubt this will fix the issue, but it’s worth trying. Could you try using the “Optimize Database” action on your server? https://support.plex.tv/articles/200392106-library-actions/
#12
I tried both HTTP and HTTPS same response.
I’ll try that.
#13
In your screenshot in if you open the dev console before you navigate to the playlist page, try clicking on the “Network” tab and filtering by /playlists that should show the request
#14
So it looks like it’s trying to send a sentry report because of a title missing somewhere but I’m seeing my client hitting a rate limit. Is there a client ID or something I can send you so you can see the earlier reports?
#15
I think I have found a single similar error in sentry
I’m presuming your URL looks something like this /playlists?key=%2Fplaylists&type=mixed&save=1
Remove &type=mixed hit enter and refresh the page. Your Playlists should load.
I am unsure how type=mixed made it into the url to break this, but I will file an issue to investigate.
If you have this issue again could you please go over the steps you took to get to that state?
Thank you for the report, sorry our Sentry is so overloaded
#16
The URL I’m getting is https://app.plex.tv/desktop#!/server/REDACTED/playlists?key=%2Fplaylists&type=photo&save=1
If I remove both the type and save params it works fine.
#17
If you remove the photo and keep the save, life should go back to normal:
https://app.plex.tv/desktop#!/server/REDACTED/playlists?key=%2Fplaylists&save=1
Sorry about that, we removed the photo route recently (it’s now under your photo albums) but it shouldn’t render to an empty page.
