Plex / Alexa - Changing users
alexa
voice-control
#1
I don't have Alexa, yet. We use Plex with user accounts.
The adult accounts require a 4 digit pin to log in on the player.
The child accounts don't have a pin, and restrict movies that can be watched by age.
What is the command to change user, and log in with / without pin-locked accounts?
e.g.:
Adult:
"Alexa, ask Plex to change user to Lisa, the pin number is 1234"
Child:
"Alexa, ask Plex to change user to Ben"
I want to ensure this is possible before dropping cash on echos for all rooms.
And does the music from Plex play on the echo's speaker?
#2
Does not currently do what you are asking.
Alexa won’t even launch the Plex app unless you add other hardware(Harmony Hub) and configure it correctly.
#3
I bought a Google Home instead. Plex is not officially supported for GH, so I’ll be using the 3rd party FlexTv plugin instead for a while, then I’ll be cancelling Plex membership and getting emBy if Plex continue to ignore Google Home.
