Plex: Brilliant but so frustrating
samsung-smart-hub
#1
Currently, Plex has ruined my weekend with the kids as I'm mad that Plex has fallen over on the ONE night I needed it.
Anyway, Plex had been running faultlessly. My films are on an old HP WMS, I was running Plex from my PC and I could access all my films from my Samsung TV. Until tonight!
I have spent the last two hours running up & down the stairs between my PC & my TV with zero results. This site is great but seems to go from the banal to the complicated very quickly leaving me way out of my depth. So here goes:
When I open Plex on my Samsung TV it says Server can't be reached
I've tried to follow all the advice about firewalls, VPN's etc. (I think) but I keep asking, if it worked before, why should I be making any changes.
I just don't get all this "Are you logged in" nonsense. My TV has Plex running. My PC also has Plex running and will run films no problem. It's just my TV can't connect to the films.#
Now I'm new to all of this so could someone please provide a step by step way to sort out connecting problems
I absolutely love Plex but my inability to fix it when it falls over means I may have to look elsewhere as tonight has been a nightmare.
Thanks for listening & for any help you can offer
#2
Check your server’s network settings -
Secure Connections should be set to Preferred
#3
Thanks. But how exactly do I do that?
#4
ms3ars. OK, I found it and it was set to prefered. However, my TV just wont conne
ct
#5
Is the firmware on your TV up to date? If not, then update it
#6
Yes it appears to be up to date
