Plex crashing on Android TV when selecting actors fix
It’ll be working fine for a while and then if you select an actor sometimes randomly it’ll just exit the app fully and you have to reopen the app go back to the movie you were on select the actor and then it will load fine and then it will be working fine for a while and then it will happen again this has been going on for a long time now but I thought somebody else would complain so now I am.
Would you be able to reproduce the issue then share your Android TV logs?
Yes can I send tomarow
