Plex doesn’t play anything
windows-store-app
#1
Could you please give me a hand on this one?
Plex stop to play everything ( Movies, Music, Etc) on all my devices after update.
the only errors in the logs are:
Feb 23, 2018 12:05:58.762 [0xaf7fdb40] INFO - Successfully retrieved OCSP response
Feb 23, 2018 12:05:59.897 [0xaf7fdb40] WARN - Crash: Crash reporting disabled
Feb 23, 2018 12:06:06.497 [0xaabfdb40] WARN - Sync: Couldn't get sync lists without subscription.
Feb 23, 2018 12:06:07.662 [0xa27fdb40] INFO - AutoUpdate: no updates available
Feb 23, 2018 12:06:08.797 [0xaf7fdb40] ERROR - Error issuing curl_easy_perform(handle): 7
Feb 23, 2018 12:06:08.797 [0xaf7fdb40] WARN - HTTP error requesting POST http://127.0.0.1:32600/devices/discover (0, No error) (Failed connect to 127.0.0.1:32600; Connection refused)
Feb 23, 2018 12:06:08.797 [0xaf7fdb40] ERROR - Error parsing content.
Feb 23, 2018 12:06:08.878 [0xaf7fdb40] ERROR - Error parsing XML.
Feb 23, 2018 12:06:10.045 [0xacbfeb40] INFO - Refreshing paths watched by LibraryUpdateManager
Feb 23, 2018 12:06:13.209 [0xa0fffb40] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (4a763f69-6616-4c8d-8674-233859175ef1, expected 38c3b143-07f3-4d74-8659-5563021c79f5)
the server is online and connected. " Fully accessible outside your network "
I would appreciate your help
thanks in advance
Regards
#2
  1. have you tried logging out and logging back in again on your plex?
  2. if that doesn't work, tried uninstalling and reinstalling? (try and remove any registry entries and the folder where plex is stored)
#3
thank you for your help, i reinstalled the entire box and it works now
