Plex for Android TV on Sony Bravia not showing artwork, but can play content fine
android-tv
fire-tv
#1
I have Plex configured behind Nginx reverse proxy and everything is working fine (iOS, Roku, PS4, Chromecast, Web), but on my new Sony Bravia TV Plex isn’t showing any artwork when browsing the app. I have my custom access URLs set as http://plex.example.com:80,https://plex.example.com:443 and Secure Connetions set to Preferred.
EDIT: Forgot to add that I’m using Plex Media Server v1.9.6.4429 and Plex for Android v6.7.1.2498.
This is how it looks on the TV:
And this is my nginx config:
upstream plex_backend {
    server 127.0.0.1:32400;
    keepalive 32;
server {
    listen 144.xx.xx.xxx:80;
    server_name plex.example.com;
    send_timeout 2h;
    location / {
        add_header X-Frame-Options SAMEORIGIN always;
        add_header X-Content-Type-Options nosniff always;
        add_header X-XSS-Protection "1; mode=block" always;
        add_header X-Robots-Tag none;
        proxy_set_header Host $host;
        proxy_set_header X-Real-IP $remote_addr;
        proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
        proxy_set_header X-Forwarded-Proto $scheme;
        proxy_http_version 1.1;
        proxy_set_header Upgrade $http_upgrade;
        proxy_set_header Connection "upgrade";
        proxy_redirect off;
        proxy_buffering off;
        proxy_pass http://plex_backend;
    location ^~ /.well-known/acme-challenge/ {
        root /opt/certbot/temp;
    location = /.well-known/acme-challenge/ {
        return 404;
    if ($host !~* ^plex\.example\.com$) {
        return 444;
server {
    listen 144.xx.xx.xxx:443 ssl http2;
    send_timeout 2h;
    ssl_certificate /etc/letsencrypt/live/example.com/fullchain.pem;
    ssl_certificate_key /etc/letsencrypt/live/example.com/privkey.pem;
    ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
    ssl_prefer_server_ciphers on;
    ssl_ciphers ECDHE-RSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:AES128-GCM-SHA256:AES128-SHA256:AES128-SHA:AES256-GCM-SHA384:AES256-SHA256:AES256-SHA:DES-CBC3-SHA;
    ssl_ecdh_curve P-256;
    ssl_session_timeout 24h;
    ssl_session_cache shared:SSL:10m;
    ssl_session_tickets on;
    ssl_buffer_size 16k;
    ssl_stapling on;
    ssl_stapling_verify on;
    ssl_trusted_certificate /etc/letsencrypt/live/example.com/chain.pem;
    resolver 8.8.8.8 8.8.4.4 valid=300s;
    resolver_timeout 5s;
    location / {
        add_header Strict-Transport-Security "max-age=63072000" always;
        proxy_redirect off;
        return 444;
Any suggestions?
Thanks.
#2
I have same issue on Android TV box and Android 7 phones. But on Android 6 phone artwork is showing
#3
@“gjorgji.d” sorry… no idea how to fix this and where to look for details on the network and potential communication issues.
@evertz: it doesn’t appear to be a general issue… working fine for me on my Sony Android TV (latest version Plex, still on Marshmallow for the TV – thanks Sony :’( ).
#4
Is that using nginx reverse proxy? The artwork shows on my TV but only if I directly connect to Plex (bypassing the reverse proxy).
#5
This was either fixed by Plex or was fixed by removing the following headers:
The fix happened at the same time when I removed the headers, then I saw the Android TV app updated. :sweat_smile:
Anyway, it’s working fine now!
The updated nginx config (tested and working with Android TV, iOS, Roku, Chromecast, Plex Web, PS4, Plex for Sony (Opera TV) and Plexamp):
server {
	send_timeout 2h;
	location / {
		gzip off;
		proxy_pass http://127.0.0.1:32400;
server {
	listen 144.xx.xx.xxx:443 ssl;
	send_timeout 2h;
	ssl_certificate /etc/nginx/ssl/plex.example.com/fullchain.pem;
	ssl_certificate_key /etc/nginx/ssl/plex.example.com/key.pem;
	ssl_stapling on;
	ssl_trusted_certificate /etc/nginx/ssl/plex.example.com/ca.pem;
	location / {
		gzip off;
#6
Was it the headers or the update? Having the same problem on Fire TV Stick right now, but don’t want to remove the HSTS…
#7
@a3rosol I have no idea, honestly.
I was trying to replicate how Plex Cloud servers are configured. They do not pass any additional headers nor they have HSTS enabled, and the SSL ciphers they use are the same on my config (mine are just rearranged). They do not serve content over HTTP/2, only HTTP/1.1.
As for HSTS, I don’t think you need it unless you’re accessing https://plex.example.com directly in your browser and you want your browser to cache the information that your site is available over encrypted connection. Besides web browsers, I don’t think other Plex clients keep information about HSTS policies.
#8
@gdob
This is really annoying me :dizzy: everything about this is weird. movies and shows are played instantly, theme music is played just fine, but once it comes to images, things don’t work? urgh. I tried your proposed fix, but that didn’t do it for me. Thanks for your help anyway!
#9
@a3rosol Did you have Secure Connetions set to Preferred and Custom Access URLs set to http://plex.example.com:80,https://plex.example.com:443 on your Plex Media Server along with the config I posted? My PMS works over both unencrypted and encrypted connections. I’m not forcing encrypted connections only.
#10
This is probably related to https://forums.plex.tv/discussion/303134/plex-android-app-not-displaying-media-images-can-stream-fine/p1
#11
I just wish Plex would officially support using reverse proxy. This whole thing feels like a hack.
