Plex for Kodi run 1080p or 4k?
plex-for-kodi
#1
Plex for kodi fun riles on 4k?
#2
It should be able to play whatever Kodi can. It uses Kodi's player
#3
But best to not update your server unless you also see a Plex For Kodi update. Seemingly according to several other posts, upgrading to server version 1.10 means you will be watching nothing at all on Plex for Kodi.
#4
Works fine with latest server version here. Also, 4K HDR works with DSplayer & madVR :smile:
#5
@bjoroy how do you go about getting that installed onto Kodi?
I’m using a Shield with Kodi installed
#6
it is in the add-on section inside of Kodi itself.
https://forums.plex.tv/discussion/246911/installation-instructions#latest
#7
I was referring to DSplayer & madVR
#8
So if I understand the point, for example:
- Kodi is on a Nvidia Shield TV
- PMS is on a Synology NAS
When I start playing, I am using Shield's CPU resources, not Synology. Am I right?
#9
Correct. 4K is an option in Settings you need to enable, however.
