Plex HTPC build for aarch64 on flathub
Hello there.
Would it be possible to build Plex HTPC for aarch64? I succesfully setup Plasma Bigscreen on a Raspberry Pi 5 with PostmarketOS, and this would really improve my setup.
Thanks so much.
With the current generation of apps, this is possible. However, it would require some developer work and I wouldn’t hold my breath. Perhaps with the promised next generation of desktop apps, maybe it’ll be targeted.
As far as I understand it, you can already run Kodi on that platform.
Maybe consider using this Kodi Plugin: PM4K / PlexMod for Kodi (18, 19, 20, 21, 22+)
thanks!
